HTTP - ACS Authentication
Jul 25th, 2007
I have just replaced a couple of old switches in my network. 1 2940-8 running 12.1(19)EA1c software with a 2960G-8 running 12.2(35)SE and a 2950-12 running 12.1(22)EA1 with a 2960G-24 running 12.2(25)SEE2.
I copied the settings across for aaa that runs on all the other switches but i cannot get http access now and network assistant is having problems accessing the switches. i also have installed 3560g 12.2(25)SEE3. This lets me login, loads the check screen but the asks me for my password again and wont let me go anyfurther. If I keep pressing cancel it eventually loads the web page with errors. These are settings on the switch.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa accounting send stop-record authentication failure
aaa accounting system default start-stop group tacacs+
aaa session-id common
ip http server
ip http authentication aaa
tacacs-server host 172.16.61.61
tacacs-server directed-request
tacacs-server key 7 **********
tacacs-server dns-alias-lookup
tacacs-server administration
radius-server source-ports 1645-1646
The version of HTTP is 1.001.001
Could anybody help with the switch settings and do i need to make any changes on the acs server?
