T1 Controller setup
Answered Question
Jul 25th, 2007
I just got a new 2811 and put in a VWIC-2MFT-T1 card. This is going to be a border router with a T1 connection to two separate ISPs. I need to configure the two T1 interfaces but can't figure out how. I get this when I do a 'sh controller t1'
MorBorder#sh controller t1
T1 0/0/0 is down.
Applique type is Channelized T1
Cablelength is long gain36 0db
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20050620, FPGA: 16, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (838 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 838 Unavail Secs
Total Data (last 3 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2700 Unavail Secs
T1 0/0/1 is down.
Data in current interval (851 seconds elapsed):
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 851 Unavail Secs
I go into config mode but can't figure out where I need to go to configure the controllers so I can get a serial interface. Any help is appreciated.
Correct Answer by paolo bevilacqua about 9 years 11 months ago
the previous reply make a lot of confusion.
The command "no-crc4" is not applicable to T1 interfaces. Your choices are SF and ESF with the latter being much more likely.
it also assumes that encapsulation has to be PPP, thing that is not ablsutely said. As your ISP and they may tell you that cisco HDLC is default unless you want PPP (there is no reson for wanting so).
And yes, you can reuse the same channel-group number for both interfaces as these will be distinguished by their numbering anyway.
Now please check you cabling to telco demarc because you have loss of signal. Please use specific T1 cable and not any ethernet patch that has different pair twisting.
Overall Rating: 5 (2 ratings)
purohit_810 Wed, 07/25/2007 - 10:00
  • Silver, 250 points or more
There are only two - three commands to configure a T1.
Conf t
controller t1
channel-group {64,56}
no-crc4
No shut
After that One Serial Interface will pop-up automatically:
Configure on that serial interface
int serial {No}
encap ppp/isdn/hdlc/frame-relay/atm
Ip address {IP address with subnetmask}
no shut
Dharmesh Purohit
qbakies11 Wed, 07/25/2007 - 10:49
Thank you for your response, it was very helpful. A question about the channel-group command, since this VWIC card has two T1 ports (T1 0/0/0 and T1 0/0/1) do I need to use different channel groups or can I use 0 for both (i.e. channel-group 0 timeslots 1-24 speed 64)?
What does the 'no-crc4' command do?
Correct Answer
paolo bevilacqua Wed, 07/25/2007 - 11:17
  • Hall of Fame,
    Founding Member
qbakies11 Wed, 07/25/2007 - 11:41
Thank you for clearing that up. I haven't been given the IP addresses or encapsulation for the circuit yet but I needed to get to the point where I could configure the serial interfaces on the card.
paolo bevilacqua Wed, 07/25/2007 - 11:57
  • Hall of Fame,
    Founding Member
After configuring channel-group under controller T1, the serial interface will appear and you can configure it.
Thanks for the nice rating and good luck!
