1130's not passing DHCP info?
Jul 25th, 2007
We have some 1130's running multiple vlans. However, we are not seeing DHCP info get past the AP's. The AP's are not using LWAPP but IOS and are being trunked backed to a 6509 CATOS. Any ideas?
jcmattos1 Fri, 07/27/2007 - 07:17
Yes the DHCP is being served off our PIX off the same vlan 313.
andrew.brazier@... Sat, 08/04/2007 - 12:37
  • Bronze, 100 points or more
Dumb question maybe but are all the VLANs defined on the APs and the switch and do they all have DHCP helpers defined?
Alejandro Corte... Sun, 08/05/2007 - 21:19
  • Silver, 250 points or more
interface VLAN5
description AP VLAN
ip address 10.5.5.1 255.255.255.0
ip helper-address 10.1.1.2
The "ip helper-address" command instructs the interface to relay DHCP requests to the DHCP server
at address 10.1.1.2
I hope this helps u
jcmattos1 Tue, 08/07/2007 - 18:41
Good suggestions all, I did add a helper address to the AP's subinterface. However, this vlan is a guest network with only Layer 2 access. There are no L3 interfaces except on the AP's subinterfaces and PIX which is its gateway and DHCP server. Oddly enough if I statically set the IP's and Gateway I can ping the gateway and other users in this vlan. But still no DHCP...Any other suggestions?
jerryard1 Tue, 08/07/2007 - 19:06
Do you have a network route on the core switch for your guest VLAN or PIX?
