1410 Slow Performance
Jul 25th, 2007
I am running a VPN over a pair of 1410's and experiencing less than stellar performance ~ about 2Mb/sec. The radios are operating at 54Mb/sec, the signal strength is -32 dBm, the signal to noise is 59dBm, the Ethernet side is running clean.
The only errors that I can see on the wireless seem to be that when under load, the Retries seem to be almost 30% of the Unicast Packets Sent, with about 5% of the retries being multiple retries. The "Protocol Defers" and "Energy Detect Defers" seem to be about 1/3 - 1/2 of the Retries number.
On the VPN side, I have looked at the counters on the ASA5510's, which are dedicated to this link and the counters seem fine. I have adjusted the TCPMSS with the ASA5510 to 1380.
I don not know exactly what is causing the Protocol Defers and Energy Detect Defers. I would imagine that some bandwidth loss could be the overhead from VPN and wireless "turn-around", but my expectation would be closer to 50%.
Thanks.
shanemason Thu, 08/02/2007 - 14:27
Did you by chance just up grade the code? One of our customers just upgraded the code on their 1410s and now have less than stellar performance.
msdavis Thu, 08/02/2007 - 15:33
No - they are recent installs. But the code we are using is the 12.4.3 code, which is the latest and we just upgraded to the latest rev, just as a measure before opening a tac case.
Did your customer back-rev the code and get the performance back? If so, may I ask what rev they went back to?
Thanks.
shanemason Thu, 08/02/2007 - 18:39
Yes, customer just emailed me and told me they rolled back, but didn't say what they rolled back to... Here's the quote (slightly edited):
Ok, pass this along?
DON?T USE THE LATEST FIRMWARE for the 1400s. When we did a physical factory reset, the **** things are flying?.
Ggrrrrr
Hope this helps, please rate if so...
msdavis Thu, 08/02/2007 - 19:58
Well - Sounds like that might be something to try - it couldn't hurt.
Thank you for relaying the information.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
