Telnet/SSH - halt screen output
Jul 25th, 2007
On an ASA, what is the keyboard key or combination of keys to halt screen output in a telnet/ssh session, similar to the <ctrl> <c> combo that halts output in the IOS? I cannot figure this out or find it via Google for anything....Thanks.
Overall Rating: 1 (1 ratings)
If you are trying to stop the output of a command from scrolling by too fast, I recommend you fix the problem not a symptom. To fix the problem, you should change the pager size. Try this in config mode..
pager lines 30
If you hit the "Q" key, it will quit back to the prompt instead of continuing with the command output.
** Please rate if this helps**
Jay
