CCM to CME Voicemail issue
Jul 25th, 2007
Hi all,
I have set up CCM 4.1(3) to talk to CME via a ICT (GK) trunk. Everything works ok except calls from a CCM phone over the ICT trunk do not get successfully forwarded to CUE (the call just drops). I can dial the VM pilot number direct from the CCM phones, it just appears to be when the CME phones forward on no answer or busy.
When i call from a PSTN phone the CME phone transfers to CUE fine.
I have checked codecs and everything is G711u for now to avoid any transcoding issues.
Any help would be greatly appreciated.
Many thanks,
Overall Rating: 5 (1 ratings)
gogasca Wed, 07/25/2007 - 10:52
...Are you using the evil dial-plan pattern command in CME?
gogasca Wed, 07/25/2007 - 10:57
Could you please attach detailed CCM trace and debug voice ccapin inout?
Include calling, called and timestamp.
gary.simpson Wed, 07/25/2007 - 11:00
Thanks for your help gogasca, i have just fixed it.
It was that the command "call-forward pattern .T" was missing. I had the "transfer-pattern .T" in, and i thought that was all that i needed.
Many thanks again,
tomtom001 Wed, 05/07/2008 - 08:16
Almost a year later and your solution helped me. +5 for you. Thanks for the assistance.
