pat on ios
Jul 25th, 2007
IOS newbie here trying to pat inside hosts to the address on e1/0.
I'm sure there's not much to it, any help would be great. Thanks everyone.
Overall Rating: 5 (4 ratings)
sundar.palaniappan Wed, 07/25/2007 - 10:56
R1(config)#ip nat inside source list 100 interface e1/0 overload
R1(config)#access-list 100 permit ip any any
R1(config)#int e1/0
R1(config-if)#ip nat outside
R1(config-if)#int e0/0
R1(config-if)#ip nat inside
Am sure you know if you want to be specific about the inside network to be NATted then change the access list accordingly.
acomiskey Wed, 07/25/2007 - 11:04
Thanks, so this is really how it is. Would it still be the same. Should e1/0 be "ip nat outside"?
Hosts inside FastEthernet0/0 are going out through e1/0.
sundar.palaniappan Wed, 07/25/2007 - 11:08
Oops sorry e1/0 should be outside. I corrected my previous post to reflect that.
You are correct. This is the IOS equivalent of the PIX global (outside) 1 interface command.
Jon Marshall Wed, 07/25/2007 - 10:59
Hi Adam
If inside hosts are and assuming they connect on e0/0 interface
access-list 1 permit
ip nat inside source list 1 interface e1/0 overload
interface e0/0
ip nat inside
interface e1/0
ip nat outside
acomiskey Wed, 07/25/2007 - 11:08
Thanks guys...
I had
and it didn't work?
sundar.palaniappan Wed, 07/25/2007 - 11:11
I believe you need to use an extended access list for NAT in IOS. Although I may have seen it work with a standard access list.
Glad you got it to work :-)
Jon Marshall Wed, 07/25/2007 - 11:15
Hi Sundar
You can use a normal access-list with NAT on IOS. Extended access-lists are useful if you want to do policy NAT.
sundar.palaniappan Wed, 07/25/2007 - 11:21
I thought so but I wasn't positive about it.
Apparently the reason why the standard ACL Adam using wasn't working is because it was showing as 'host' rather than 'any'.
