1841 VWIC 1MFT-T1 configuration
Jul 25th, 2007
It's been a while. I need to configure an interface for the T1 controller. Any help would be appreciated. I thought it was a virtual serial interface, but can't for the life of me get it going here. I am open to suggestions.
pstebner1 Wed, 07/25/2007 - 12:23
Hi William-
Assuming you have the framing and linecode, first you configure the controller:
Router(config)#controller t1 0/1
Router(config-controller)#framing esf
Router(config-controller)#linecode b8zs
Router(config-controller)#channel-group 1 timeslots 1-24
Then the serial interface:
Router(config-controller)#int s0/0:1
Router(config-if)#ip address xx.xx.xx.xx 255.255.yy.yy
(if it's a point-to-point):
Router(config-if)#encap ppp
Tha't about it. Let me know if you have any specific requirements that I didn't cover.
HTH,
Paul
william.culver@... Wed, 07/25/2007 - 12:38
It's all coming back. I think that should do it. Will know for sure when the line gets turned up tomorrow. Appreciate the help.
jay77jay77 Wed, 07/25/2007 - 18:05
hi its not necessarily be encap PPP on point to point interface. Even if u dont do the
encap PPP command the link shud come up.
If you do encap PPP, you need to do it on the remote end of the link too...
Cheers!
