isis Error
Jul 25th, 2007
have a router 2520 "IOS (tm) 2500 Software (C2500-I-L), Version 12.3(16), RELEASE SOFTWARE (fc4)" Flash "c2500-i-l.123-16.bin".
When i give Command Router isis, it gives error massege "Protocol not in this image"
Any help in this regard please.
Irfan Khan
bwgray Wed, 07/25/2007 - 11:53
Your IOS image does not have the ISIS protocol in it. Off hand not sure which one for your particular model, but that's what the error is referring to.
sr2675402 Wed, 07/25/2007 - 12:04
I can see that protocol is supported since i am getting this output
R1(config)#router ?
bgp Border Gateway Protocol (BGP)
Enhanced Interior Gateway Routing Protocol (EIGRP)
isis ISO IS-IS
iso-igrp IGRP for OSI networks
mobile Mobile routes
odr On Demand stub Routes
ospf Open Shortest Path First (OSPF)
rip Routing Information Protocol (RIP)
bwgray Wed, 07/25/2007 - 12:25
Using the cisco feature navigator and the IOS Image name you provided, that particular IOS does not contain the ISIS protocol:
iBGP Multipath Load Sharing
IGMP MIB Support Enhancements for SNMP
IGMP Version 2
IGMP Version 3
Integrated routing and bridging (IRB)
Interface Index Display
Interface Index Persistence
Interface Range Specification
IP Enhanced IGRP Route Authentication
IP Multicast Load Splitting across Equal-Cost Paths
IP Named Access Control List
IP Precedence for GRE Tunnels
IP Routing
IP RTP Priority
IP SLAs - DHCP Operation
IP SLAs - Distribution of Statistics
IP SLAs - DNS Operation
IP SLAs - FTP Operation
IP SLAs - History Statistics
IP SLAs - HTTP Operation
IP SLAs - ICMP Path Echo Operation
IP SLAs - One Way Measurement
IP SLAs - Reaction Threshold
IP SLAs - Scheduler
IP SLAs - SNA LU2 Echo
IP SLAs - SNMP Support
IP SLAs - TCP Connect Operation
IP SLAs - UDP Echo Operation
IP SLAs - UDP Jitter Operation
IP Summary Address for RIPv2
IPSec Through Network Address Translation Support
ISDN Advice of Charge (AOC)
ISDN Caller ID Callback
ISDN Cause Code Override
Line Printer Daemon (LPD)
Lock and Key
I've just pasted the section around the ISIS protocol for you. Again from IOS image c2500-i-l.123-16.bin
