Multicast traffic generator
Jul 25th, 2007
Hi All,
Is there a way I can run multicast traffic generation on a router? I.E. A software piece, a configuration ect. I have routers but want to generate traffic for them, so I can practice multicast labs effectivly.
scottmac Wed, 07/25/2007 - 13:09
Aside from some routing protocols, no, nothing substantial.
For some classes, we used stuff like iTunes or other music multicaster on a scrap machine. The reward for properly configuring your router was that you could receive music ...
Some of the Video / webcam software should be able to put out some MC frame as well.
Good Luck
jcrussell Wed, 07/25/2007 - 13:12
Check out the rtr or ip sla commands, depending on which IOS version you are using. They can be used to generate a constant stream of traffic.
A simple "ping repeat 10" works for quick checks, too.
andrew.burns Thu, 07/26/2007 - 04:00
Yes, you can use MRM (multicast routing monitor) for this purpose. It is described in the IP Multicast Configuration Guide:
The benefits of the MRM are as follows:
*MRM allows network personnel to generate test flows without having to use host devices.
*MRM can verify a multicast environment prior to an event. You need not wait for real multicast traffic to fail in order to find out that a problem exists. You can test the multicast routing environment before a planned event.
*MRM provides easy diagnostics. The error information is easy for the user to understand.
*MRM is scalable. This diagnostic tool works well for many users.
