Does Catalyst 3550 support inter vlan routing
lifeisgreat
Does Catalyst 3550 switch support inter vlan routing ?
12 Replies 12
lamav
Level 8
Level 8
of course
I am having the same problem too...do i need to buy any modules for add-ons in order to configure inter vlan routing ? mine running on 12.1version....
The 3550 is a L3 IOS-based switch. You must turn on ip routing.
What exactly are you having a problem doing?
Basically I am trying to configure an isolated LAN using CAT3550 but at the same time to configure intervlan routing so that it can talk to my production lan.
am trying to setup an secured network...
Jon Marshall
The 3550 does support inter-vlan routing but the routing protocols it supports depends on the software version ie the SMI version only supports RIP + static routing.
For other routing protocol support you need the EMI version.
Jon
Does mine supports? I have attached my version here.
------------------ show version ------------------
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(20)EA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 04-Feb-04 23:08 by yenanh
Image text-base: 0x00003000, data-base: 0x006B3334
ROM: Bootstrap program is C3550 boot loader
uptime is 13 weeks, 5 days, 18 hours, 54 minutes
System returned to ROM by error - Instruction Access Exception (0x0400)!, PC 0x334C322C
System restarted at 17:26:28 SPORE Wed Aug 17 2005
System image file is "flash:c3550-i9q3l2-mz.121-20.EA1/c3550-i9q3l2-mz.121-20.EA1.bin"
cisco WS-C3550-24-PWR (PowerPC) processor (revision E0) with 65526K/8192K bytes of memory.
Processor board ID CAT0803Z3E6
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Motherboard assembly number: 73-8100-07
Power supply part number: 341-0029-03
Motherboard serial number: CAT080401ZD
Power supply serial number: LIT075001TN
Model revision number: E0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number:
Configuration register is 0x10F
Yes they all do. Can you post config of your switch if you are having problems.
Jon
lim,
Do this: #ip routing
Create a vlan and add a port into that vlan
Then do #interface vlan (number)
put the Ip address of the vlan interface
With the interface vlan XXX command you enable intervlan routing between vlans.
If you want your production lan to connect to this 3550, then you need to setup some type of connection to it. You need to allow your production lan to be able to route to the 3550 either through static routes or a routing protocol.
Lim:
Interestingly enough, I found myself trying to do the same thing using a 3550 switch a few years back.
I think I understand what you're trying to do.
I'll tell you the way I did it...
I created a segregated vlan by using very granular ip access lists to filter traffic.
YOu have to create the SVI interface for the vlan, apply a network IP address and mask, turn up the SVI with the "no shutdown" command, and then advertise that network under the route protocol instance.
Do the same with other vlans. Create them and add their networks to the routing process on the switch.
NOTE: For any SVI interface to go to an "up, up" state, at least ONE end-device must be placed in that vlan, and that device must be successfully connected to the ethernet interface. In other words, the switch's physical interface that is connected to the end-device must be in an "up, up" state.
Once the SVIs for EACH vlan you have created are "up,up" and the routing process has been enabled, devices on each vlan will become reachable, including on the segregated vlan.
Now, to make a vlan segregated, you can use granular IP access lists to filter the traffic.
Victor
I have done the above and i am still getting crosstalk with DHCP.
Any help??
Here is part of my config on the core switch...
My secondary DHCP is plugged in to port gig 0/12 and that is currently set to access vlan 15 which is also my new gear.
interface GigabitEthernet0/12
switchport access vlan 15
switchport trunk allowed vlan 15
no ip address
interface Vlan1
ip address 10.0.100.3 255.255.0.0
interface Vlan2
description hotel_admin
no ip address
interface Vlan12
description TMOBILE
no ip address
interface Vlan15
ip address 10.20.0.8 255.255.248.0
ip helper-address 10.20.0.1
ip default-gateway 10.0.0.1
ip classless
ip route 10.20.0.0 255.255.248.0 10.20.0.1 name MX400
ip http server
snmp-server engineID local 800000090300000CCEAC8001
snmp-server community tbmanager RW
snmp-server community tbconferences RO
snmp-server host 10.0.0.1 tbconferences
line con 0
password 7 0459190D210F1D
login
line vty 0 4
password 7 0111140F752557
login
line vty 5 15
password 7 13070519252255
login
Please start a new thread...this one is 6 years old...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
