eigrp
Answered Question
Jul 25th, 2007
Why does my Cisco 3662,3841, catalyst 3750s send EIGRP information to address 224.0.0.10?
Correct Answer by Jon Marshall about 9 years 10 months ago
The passive-interface command stops hello packets being exchanged between EIGRP neighbours. This means a neighborship si not formed and so no routing updates are sent or received.
You configure it under your router eigrp section eg
router eigrp 1
passive-interface fa0/1
This means any other EIGRP routers on the subnet that fa0/1 connects to will not exchange hellos with this router and hence no neighborship is formed.
The impact of using this command is that you have just stopped the router receiving routing updates and sending routing updates on it's fa0/1 interface. This may well result in an incomplete routing table.
Attached is a link to a doc about use of passive-interface in EIGRP.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0a.shtml
Jon
No it won't cause congestion on a LAN as it really doesn't account for much of the traffic you will see on a LAN.
What should be said is that even though it is a multicast address all devices, routers, PC's, servers, on that subnet will see the update.
Jon
Overall Rating: 4.7 (3 ratings)
Richard Burts Wed, 07/25/2007 - 18:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Bernadette
This is because part of the specification of the EIGRP routing protocol is that it sends routing updates using multicast address 224.0.0.10. This is similar to how OSPF sends updates to multicast addresses of 224.0.0.5 and 224.0.0.6.
Rick
bericaleb Wed, 07/25/2007 - 18:42
is this a good thing for the Ethernet LAN? Does it causes congestion on the network?
Correct Answer
Jon Marshall Wed, 07/25/2007 - 18:44
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
jlhainy Wed, 07/25/2007 - 19:57
If it bothers you to have eigrp packets multicasted onto your LAN, you can stop that from happening by using the passive-interface command on your eigrp AS statement in your config.
bericaleb Wed, 07/25/2007 - 22:22
hi
What does this command do exactly? What are the impact of using this command. How do we configure this command?
Correct Answer
Jon Marshall Wed, 07/25/2007 - 22:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
router eigrp 1
Jon
Jon Marshall Wed, 07/25/2007 - 18:38
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
EIGRP uses the multicast address 224.0.0.10 to communicate with any other EIGRP speaking routers on the network. It is the way the routing protocol has been written. It is not unique in using multicast addressing eg
OSPF uses
224.0.0.5 = all OSPF routers
224.0.0.6 = DR/DBR
Jon
jbrunner007 Fri, 07/27/2007 - 11:43
to actually get the behavior where eigrp uses unicast, and not multicast you need the
neighbor x.x.x.x under the eigrp process.
If you do this the interface on which this neighbor can be found switches from using multicast to unicast.
