4503 always boots to ROMMON
Jul 25th, 2007
Hello!
Our Cisco 4503 always when reboots comes to the rommon, but we neet it to boot IOS automatically. Configuration register is 0x102, but it doesn't help. We configured "boot system flash cat4000-i9s-mz.122-25.EWA4.bin", where "boot system flash cat4000-i9s-mz.122-25.EWA4.bin" is the default and the only IOS on flash. But it also doesn't help!
Could you tell me what to pay attention to to understand the problem, and help to make the 4503 to boot automatically?...
Amit Singh Wed, 07/25/2007 - 20:48
  • Cisco Employee,
You are using a wrong bootvariable.
Please set the boo variable gto following:
Switch#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#boot system flash bootflash:cat4000-i9s-mz.122-25.EWA4.bin
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_example09186a0080094ecf.shtml
You should be all set to go fine after this.
HTH,Please rate if it does.
-amit singh
abatuyeva Mon, 07/30/2007 - 20:34
Thanks asingh2!
I'll rate this post after I'll check this. Now we can't reboot the Cisco...
