Trouble uploading IOS via tftpd32
mohammedmahmoud Wed, 07/25/2007 - 22:47
  • Green, 3000 points or more
Can you try loading the smallest IOS you can get.
HTH,
Mohammed Mahmoud.
mohammedmahmoud Thu, 07/26/2007 - 03:49
Yes it might be a tftp sw problem try a different software.
HTH,
Mohammed Mahmoud.
Here is a little more detail on the problem that I'm having:
I have 3 2500 routers. I purchased memory to max out the memory on all of the routers (16MB for each) and replaced the old memory. When I power up any of the routers it loads it's boot image and the prompt reads - router (boot)>
If I run the command the "show flash" it says
System flash directory:
No files in System flash
[0 bytes used, 16777216 available, 16777216 total]
16384K bytes of processor board System flash (Read/Write)
I want to load IOS version 12.3 so I try to load it via tftp.
router(boot)#copy tftp flash
Address or name of remote host [255.255.255.255]?10.70.106.1
Source file name?c2500-is-l.123-5b.bin
Destination file name [c2500-is-l.123-5b.bin]?
Accessing file 'c2500-is-l.123-5b.bin' on 10.70.106.1...
Loading c2500-is-l.123-5b.bin from 10.70.106.1 (via Ethernet0): ! [OK]
Device needs erasure before copying new file
Erase flash device before writing? [confirm]Yes
Copy 'c2500-is-l.123-5b.bin' from server
as 'c2500-is-l.123-5b.bin' into Flash WITH erase? [yes/no]yes
Erasing device... eeeeeeeeeeeeeeeeeeee...eras
ed
Loading c2500-is-l.123-5b.bin from 10.70.106.1 (via Ethernet0): !!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!Parity (control reg=0x718) Error, address: 0xE092E4 at 0x1098EA4 (PC)
I get the parity error and then it reboots. Anyone have any suggestions?
EPHRAIM MANI Sat, 07/28/2007 - 01:30
  • Bronze, 100 points or more
there are more chances of being bad in this case as one of them is working. Do clean the Simm slots before inserting the memory simms.
Kindly rate all the posts if helpful
