CCM 5.1 Cluster query
gogasca Wed, 07/25/2007 - 21:10
  • Green, 3000 points or more
If you check in the IP Phone itself Option 21 and above the 2 servers are listed?
DO you use IP address or hostname for Server name under CCMAdmin|Server?
I recommend you IP address or have a working dNS server.
Let me know that first.
gogasca Wed, 07/25/2007 - 21:22
Which one is listed as Active?
You may change to IP address under CCMAdmin|Server and reset 1 Phone so it can get this new config...or restart TFTP service then reset IP Phone so new files gets created, then check again what its in the display, the IP addresses should be there.
