E1 back to back on same H323 Gateway
Jul 26th, 2007
I have a test plateforme with to PSTN provider and with only one 2821 voice gateway.
I'd like to simulate the PSTN by linking the 2 E1 controller on the VWIC-2MFT-T1/E1 of my gateway using to E1 cross-cable.
At the beginnig I did in MGCP but it didn't work probably due to CCM loop avoidance mechanism, then I did in H323 but it still not working.
Do you have any idea if it is possible or not?
I attached to conf if you want to have a look.
PS:all test numbers start with 69XXX ,I created a route pattern "*.69XXX" to use the H323 gawteway to force call to go through the GW
luc.charpentier Thu, 07/26/2007 - 04:59
Any ideas ?
Could b every usefull with only 1 voice gateway and no PSTN provider.
Luc
phershaw Fri, 07/27/2007 - 02:08
Luc,
For starters, try making the following changes:
dial-peer voice 100
incoming called-number .
dial-peer voice 1
destination-pattern .T
debug isdn q931 should help you see what's happening.
Phil
