07-26-2007 01:48 AM
The network topology is
Modem --> [FXS][cisco 2821][E1] --> ISDN PRI --> [E1][cisco 2811][PVDM2-36DM]
ISDN PRI link is operated correctly, debug isdn q931 shows that connection is established. Info message is
*Jul 23 06:27:45.407: %ISDN-6-CONNECT: Interface Serial1/0:1 is now connected to 555 N/A
Unfortunately, no carrier signal is going from modem to line.
Configuration of Cisco Routers is below.
1st (2821)
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-2,16
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice modem
no cdp enable
dial-peer voice 1 pots
destination-pattern 555
port 0/3/0
voice-port 0/3/0
cptone RU
dial-peer voice 888 pots
destination-pattern .T
port 0/2/0:15
2nd (2811)
controller E1 1/0
framing NO-CRC4
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn timer T310 120000
isdn not-end-to-end 64
isdn protocol-emulate network
no cdp enable
line 0/322 0/357
modem InOut
07-26-2007 02:40 AM
What is the E1 hardware you are using ? (do show diag to know). The PVDM2-DM works only with NM-xT1/E1.
07-26-2007 02:56 AM
Yes, of course, it is well known fact. We are using NM-1CE1T1-PRI. See "show diag" output below.
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC11070F5L
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-03
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20070214
Chassis Serial Number : FHK1109U00A
Chassis MAC Address : 001b.2aa3.c1c8
MAC Address block size : 24
CLEI Code : COM7C00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-04
Version Identifier : V04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 31 30 37 30 46 35 4C 40
0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 03 42 41 30
0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 3F 46 C2 8B 46 48 4B 31 31 30 39
0x40: 55 30 30 41 C3 06 00 1B 2A A3 C1 C8 43 00 18 C6
0x50: 8A 43 4F 4D 37 43 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 04 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
PVDM Slot 0:
36 port PVDMII digital modem PVDM daughter card
Part Number : 73-10102-03
Board Revision : C0
Fab Version : 03
PCB Serial Number : FOC10354YRW
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-36DM
Version Identifier : V01
0x00: 04 FF 40 04 90 41 01 00 82 49 27 76 03 42 43 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 30 33 35
0x20: 34 59 52 57 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8A 50 56 44 4D 32 2D 33 36 44 4D 89 56 30 31 20
0x40: D9 02 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
NM-1CE1T1_PRI Port adapter, 1 port
Top Assy. Part Number : 800-21550-02
Board Revision : A0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : FOC104753CA
RMA History : 00
Fab Part Number : 28-5935-03
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Field Diagnostics Data : 00 00 00 00 00 00 00 00
Product (FRU) Number : NM-1CE1T1-PRI
0x00: 04 FF 40 03 9D 41 01 00 C0 46 03 20 00 54 2E 02
0x10: 42 41 30 80 00 00 00 00 02 03 C1 8B 46 4F 43 31
0x20: 30 34 37 35 33 43 41 03 00 81 00 00 00 00 04 00
0x30: 85 1C 17 2F 03 C4 08 00 00 00 00 00 00 00 00 C5
0x40: 08 00 00 00 00 00 00 00 00 CB 8D 4E 4D 2D 31 43
0x50: 45 31 54 31 2D 50 52 49 89 56 30 31 20 FF FF FF
07-26-2007 03:33 AM
Which exact IOS version are you using ?
07-26-2007 04:27 AM
Initial IOS version is c2800nm-ipbase-mz.124-11.T.bin
Also were tested
c2800nm-ipvoicek9-mz.124-15.T1.bin
c2800nm-ipbasek9-mz.124-15.T1.bin
07-26-2007 05:55 AM
Hi, have you configure modem country as per documentation ?
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a00806b941f.html
07-26-2007 06:35 AM
Do you mean "modem country v12
Yes, command "modem country v12 russia" is in configuration of second router (with PVDM2-36DM)
07-26-2007 10:03 AM
Then I wouldn't know what to suggest and you may need to give the case to the TAC for help.
07-29-2007 09:42 PM
The problem is solved. IOS command "network-clock-select 1 E1 1/0" was needed at the beginnig of router configuration (2nd router with E1 PRI and PVDM2-36DM).
07-30-2007 01:15 AM
Thanks for letting us know. The command is mandatory in all T1 ? E1 application however it didn't occurred to me to ask if you had it.
