ASA to Router VPN Access lists
Jul 26th, 2007
Hi, I have an issue tying down ports on an ipsec vpn between an asa5510 and a 1801 router. I can get the tunnel up no problem with allowing ip traffic but when I try to tie it down it all goes wrong.
I would appreciate any help on this. I am trying just to allow tcp: http,https and ftp and ICMP also.
Thanks in advance
ciaran
bbaley Wed, 08/01/2007 - 10:10
You need to configure an access list . Here is an example access-list 100 permit udp any host 10.1.1.25 eq isakmp
purohit_810 Wed, 08/01/2007 - 12:08
  • Silver, 250 points or more
To allow all the protocols:
object-group service TCP tcp
port-object eq telnet
port-object eq www
port-object eq ftp-data
port-object eq domain
port-object eq https
port-object eq ftp
port-object eq citrix-ica
port-object eq 3389
port-object eq 8080
port-object eq ssh
port-object eq 7070
port-object eq 6080
port-object eq rtsp
port-object eq 8200
port-object eq 2097
port-object eq 5012
port-object eq 990
object-group service UDP udp
port-object eq echo
port-object eq www
port-object eq isakmp
port-object eq 4500
port-object eq 10000
access-list 102 extended permit udp any any object-group UDP
access-list 102 extended permit tcp any any object-group TCP
access-list 102 extended permit esp any any
Dharmesh Purohit
ciaran1977 Thu, 08/02/2007 - 01:24
Thanks for the responce Dharmesh. But you can only use object-goups on the asa, on the router (1801) you can not define object-groups. When you try to mix object groups (on the asa) with access lists (on the router) I cannot get the tunnel up.
michaeltedeschi Mon, 08/06/2007 - 19:58
On your router you need an acl like so in your outside int acl
access-list 105 permit ahp host remote ip host local ip
access-list 105 permit esp host remote ip host local ip
access-list 105 permit udp host remote ip host local ip eq isakmp
access-list 105 permit udp host remote ip host local ip eq non500-isakmp
access-list 105 permit ip remote internal network 0.0.3.255 local internal network 0.0.7.255
