Martin Ermel Fri, 07/27/2007 - 01:21
according to CISCOs SNMP Object Navigator this is part of the OLD-CIOSC-CPU-MIB, which is supported for the cisco1800 series with some 12.3(8) releases :
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.2.1.58&submitValue=SUBMIT&submitClicked=true
right after the MIB field in the table there is a link to 'View Supporting Images'
there is also the CISCO-PROCESS-MIB
cpmCPUTotal5secRev (.1.3.6.1.4.1.9.9.109.1.1.1.1.6)
cpmCPUTotal1minRev (.1.3.6.1.4.1.9.9.109.1.1.1.1.7)
cpmCPUTotal5minRev (.1.3.6.1.4.1.9.9.109.1.1.1.1.8)
but it is also supported starting with c180x-adventerprisek9-mz.12.3-8.YI
Pushkar Sambhoos Mon, 07/30/2007 - 00:00
Could you provide and output of your 'show ver' from the 1800, so can go ahead and provide you with the exact OID for the CPU usage.
-- Pushkar
tripxie_83 Tue, 07/31/2007 - 08:01
This bit of info you are looking for i think?
I went and looked at the site and found the IOS i have but i culd not find the oid.
It shuld be verry nice if you culd find it.
ROM: System Bootstrap, Version 12.3(8r)YH6, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, C180X Software (C180X-ADVIPSERVICESK9-M), Version 12.4(2)XA, RELEASE SOFTWARE (fc3)
System image file is "flash:c180x-advipservicesk9-mz.124-2.XA.bin"
Martin Ermel Tue, 07/31/2007 - 08:27
this IOS should support bot mibs OLD-CISCO-CPU and the CPU-PROCESS-MIB.
could you provide the output of a snmpwalk on .1.3.6.1.4.1.9.2.1 ?
tripxie_83 Tue, 07/31/2007 - 08:45
Shows 0.
I rememberd that the output of "show processes cpu history" gave a bit strange result also, Just showing stats on 72hrs, posting in another message.
enterprises.9.2.1.1.0 = STRING: "
Copyright (c) 2005 by cisco Systems, Inc.
enterprises.9.2.1.2.0 = STRING: "power-on"
enterprises.9.2.1.3.0 = STRING: "VPN-Duo-TMHQ"
enterprises.9.2.1.4.0 = STRING: "yourdomain.com"
enterprises.9.2.1.5.0 = IpAddress: 213.64.86.42
enterprises.9.2.1.6.0 = IpAddress: 0.0.0.0
enterprises.9.2.1.8.0 = INTEGER: 57525004
enterprises.9.2.1.9.0 = INTEGER: 1118
enterprises.9.2.1.10.0 = INTEGER: 500
enterprises.9.2.1.11.0 = INTEGER: 22762004
enterprises.9.2.1.12.0 = INTEGER: 0
enterprises.9.2.1.13.0 = INTEGER: 500
enterprises.9.2.1.14.0 = INTEGER: 104
enterprises.9.2.1.15.0 = INTEGER: 73
enterprises.9.2.1.16.0 = INTEGER: 24
enterprises.9.2.1.17.0 = INTEGER: 150
enterprises.9.2.1.18.0 = INTEGER: 10359160
enterprises.9.2.1.19.0 = INTEGER: 1053
enterprises.9.2.1.20.0 = INTEGER: 3441
enterprises.9.2.1.21.0 = INTEGER: 3464
enterprises.9.2.1.22.0 = INTEGER: 600
enterprises.9.2.1.23.0 = INTEGER: 48
enterprises.9.2.1.24.0 = INTEGER: 11
enterprises.9.2.1.25.0 = INTEGER: 150
enterprises.9.2.1.26.0 = INTEGER: 3400345
enterprises.9.2.1.27.0 = INTEGER: 262
enterprises.9.2.1.28.0 = INTEGER: 1275
enterprises.9.2.1.29.0 = INTEGER: 1298
enterprises.9.2.1.30.0 = INTEGER: 1536
enterprises.9.2.1.31.0 = INTEGER: 9
enterprises.9.2.1.32.0 = INTEGER: 8
enterprises.9.2.1.33.0 = INTEGER: 150
enterprises.9.2.1.34.0 = INTEGER: 1440486
enterprises.9.2.1.35.0 = INTEGER: 426
enterprises.9.2.1.36.0 = INTEGER: 1899
enterprises.9.2.1.37.0 = INTEGER: 1858
enterprises.9.2.1.38.0 = INTEGER: 5024
enterprises.9.2.1.39.0 = INTEGER: 1
enterprises.9.2.1.40.0 = INTEGER: 1
enterprises.9.2.1.41.0 = INTEGER: 10
enterprises.9.2.1.42.0 = INTEGER: 0
enterprises.9.2.1.43.0 = INTEGER: 23
enterprises.9.2.1.44.0 = INTEGER: 48
enterprises.9.2.1.45.0 = INTEGER: 49
enterprises.9.2.1.46.0 = INTEGER: 102
enterprises.9.2.1.47.0 = INTEGER: 0
enterprises.9.2.1.48.0 = IpAddress: 0.0.0.0
enterprises.9.2.1.49.0 = ""
enterprises.9.2.1.51.0 = IpAddress: 0.0.0.0
enterprises.9.2.1.52.0 = ""
enterprises.9.2.1.56.0 = INTEGER: 0
enterprises.9.2.1.57.0 = INTEGER: 0
enterprises.9.2.1.58.0 = INTEGER: 0
enterprises.9.2.1.59.0 = INTEGER: 5000
enterprises.9.2.1.60.0 = INTEGER: 0
enterprises.9.2.1.61.0 = STRING: "cisco Systems, Inc.
170 West Tasman Dr.
San Jose, CA 95134-1706
U.S.A.
Ph +1-408-526-4000
Customer service 1-800-553-6387 or +1-408-526-7208
24HR Emergency 1-800-553-2447 or +1-408-526-7209
Email Address [email protected]
World Wide Web http://www.cisco.com"
enterprises.9.2.1.62.0 = INTEGER: 18024
enterprises.9.2.1.63.0 = INTEGER: 1
enterprises.9.2.1.64.0 = INTEGER: 1
enterprises.9.2.1.65.0 = INTEGER: 4
enterprises.9.2.1.66.0 = INTEGER: 0
enterprises.9.2.1.67.0 = INTEGER: 23
enterprises.9.2.1.68.0 = INTEGER: 48
enterprises.9.2.1.69.0 = INTEGER: 49
enterprises.9.2.1.70.0 = INTEGER: 0
enterprises.9.2.1.71.0 = INTEGER: 0
enterprises.9.2.1.72.0 = IpAddress: 0.0.0.0
enterprises.9.2.1.73.0 = STRING: "flash:c180x-advipservicesk9-mz.124-2.XA.bin"
enterprises.9.2.1.74.0 = INTEGER: 3
tripxie_83 Tue, 07/31/2007 - 08:46
11111
100
90
80
70
60
50
40
30
20
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
11 1111121111111111 1141112 111111111111 11121 11 111111
100
90
80
70
60
50
40
30
20
10 *
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
11 1 1 1 311 1111 11 2111 11221 1 121 1111121 11 1 11 1 11 1 1
8007563857085127532168458600329812542818636811419969008157972930972567
100
90
80
70
60
50
40 *
30 * * *
20 * * * * * ** *** *** ** * *
10 ************************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
tripxie_83 Fri, 08/03/2007 - 11:31
I noticed when i got help in this thread that the problem is probly that there are no values on 5min scince the graphs i found were empty on all but 72hrs, Any advice on how this is solved?
