Catalyst 3750 software configuration guide
Answered Question
Jul 26th, 2007
I have been searching for the latest 3750's configuration guide on the CCO page, but the latest I can find is for IOS 12.2.
Can anyone tell me where is the guide for IOS 12.4 ?
Thanks in advance.
Correct Answer by Amit Singh about 9 years 9 months ago
3750 runs on 12.2S train only. It doesnot run on 12.14 Train. 12.4 Train IOS is only for Cisco routers. You can get the config guide for 12.2S series from www.cisco.com/univercd
HTH,Please rate if it does.
-amit singh
Correct Answer by b.athanasiadis about 9 years 9 months ago
The switch IOS versioning is not the same as that for routers. 12.2(37)SE is the latest version for 3750s.
You could Cisco's software center to confirm this under Software Downloads.
Overall Rating: 5 (2 ratings)
Correct Answer
b.athanasiadis Thu, 07/26/2007 - 05:24
Correct Answer
Amit Singh Thu, 07/26/2007 - 05:24
  • Cisco Employee,
-amit singh
s.debenito Fri, 07/27/2007 - 04:28
Thank you so much for your answer. That URL is really interesting!!
Sergio.
