SNMP Monitoring
Jul 26th, 2007
I'm trialing solarwinds to monitor my test network here.
I configured the following command on my router:
snmp-server community private RW
In solarwinds, it asks for the I.P address and SNMP Community String.
When I enter the above fields, i'm getting error messages:
'10.0.0.1' does not respond to SNMP Queries using 'private'
Any steps or configurations which i'm doing wrong here?
Anonymous (not verified) Thu, 07/26/2007 - 07:09
Richard Burts Thu, 07/26/2007 - 07:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dan
What you have posted looks ok. I would suggest that you verify that the addresses are correct (is the router really pointing at the right address for the server, and is the server really pointing at the right address for the router). If the addresses are correct I would suggest that you verify connectivity between the router and the server (ping is good for that). If connectivity is good then I would suggest that you check for access lists that might block SNMP (either on the router or on some intermediate router between this router and the server).
Rick
danny9797 Wed, 08/01/2007 - 10:36
Thanks a lot guys,
I believe is b/c i'm running a trial version of the software, it's not allowing me to use certain features. I couple of features worked for me. I'm not sure why the program should just indicate that the feature is locked due to the trial licensing as opposed to denying my snmp password.
I believe this is the issue anyhow...
I have a question about the smtp string. What is the RO and RW for? Can I monitor the interface if it's set to read only? Why would I have to use the writing attribute?
dtushing123 Wed, 08/01/2007 - 11:02
You could monitor statistics using the read only community. With the read write you could perform things such as shutdown and interface etc.
Example.
You could use a tool like Ciscoworks LMS to provision vlans, ports etc using read/write snmp community or just monitor which ports are in use using the read community.
slhulshizer Thu, 08/02/2007 - 13:51
I have had this problem when the firewall is blocking snmp as well as the above mentioned acl.
