Can't register with sip provider (sipgate.co.uk)
Jul 26th, 2007
Hi All
Have cme 4.01, IOS 12.5(15)T. But recently can't register with sip provider via sip-ua.
I have account with sipgate.co.uk that was working fine until recently with sip-ua as follows:
sip-ua
authentication username ????? password ?????
no remote-party-id
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 10
timers connect 100
timers connection aging 30
registrar ipv4:217.10.79.23 expires 600
sip-server ipv4:217.10.79.23
and a ephone-dn with secondary number set as my username above.
debug ccsip all shows :
SIP/2.0 403 Forbidden (client configuration error)
I've spoken with provider who tell me expires has been reduced from 3600 to 600 and that is only change.
Any ideas?
shikamarunara Thu, 07/26/2007 - 08:03
Anthony,
A few days ago I ran into a similar issue, but it was for setting up a SIP trunk in CM 4.2 to an ICX. I discovered that the problem I was having was related to configuring authentication properly and I discovered it after running a packet sniff. In my case, the SIP trunk was passing my Caller ID DN as the username (which the SIP provider had no use for, so it couldn't work.)
A packet sniff will help you find where the hang up is happening.
-Shikamaru
anthonyfear Thu, 07/26/2007 - 08:29
Thanks for the suggestion but I'm going to change provider because a couple of tests with other providers seem to work fine with similar config.
shikamarunara Thu, 07/26/2007 - 08:32
Yeah, sounds like you're having an authentication issue. And, yeah, if the other providers make your life easier you SHOULD change :)
-Shikamaru
andriyhar Tue, 08/07/2007 - 12:25
Try this:
registrar ipv4:217.10.79.23:5060 expires 600
sip-server ipv4:217.10.79.23:5060
