07-26-2007 08:16 AM - edited 03-05-2019 05:30 PM
I have a PDF that details this concept fairly well, except all of the example switches are Cats. Are any IOS switches able to be VMPS servers? It appears they all could be VMPS clients.
TIA,
Lee
Solved! Go to Solution.
07-26-2007 10:15 AM
Lee,
VMPS server is not supported on IOS switches. Its only supported on CatOS switches and there are no plans to support it on IOS.
However, if you are looking for dynamic vlan assignment, you can use IEEE 802.1x feature on the switchports and have the ACS assign the dynamic vlan based on the user-ID's.Please see the link below for more info:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_31a/config/dot1x.htm
HTH,Please rate if it does.
-amit singh
07-26-2007 10:15 AM
Lee,
-amit singh
