Are modules for the 3640 router hot-pluggable
Answered Question
Jul 26th, 2007
Can you add an NM to a 3640 while it's running without destroying things? I'd like to add a third fast ethernet port.
Correct Answer by ankbhasi about 9 years 3 months ago
Hi Friend,
With regards to the NM module being hot swappable , the 3640 hundred series does not support hot swapaable only certain modules in the 3660 series will support that.
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
