ip routing
Jul 26th, 2007
We recently established a metro link connecting a remote office. Site A is a public network, Site B is a private network. The routers appear to be talking to each other. Site A also has a Cisco 1605R connecting it to the Internet. I ran the following command on it the establish a static route to the router to Site B:
config terminal ip route
However, commands sent to the private network still are being routed to the Cisco.
Am I missing another command somewhere?
Here is the result from a 'show ip route'
united_imaging>show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is to network is subnetted, 1 subnets
C is directly connected, Ethernet1
S [1/0] via
S* is directly connected, Serial0
Thank you in advance for you help,
Amit Singh Thu, 07/26/2007 - 09:48
Could you please send the config for both the routers Router A and Router B. Do a traceroute to 192.168.1.x any host and check where are you going through it.
Also, Please paste a brief network topology.
-amit singh
ui1cisco2 Fri, 07/27/2007 - 08:39
Sorry, what exactly are you looking for as far as the topology? I can create a simple diagram if your wish.
Thank you again,
ui1cisco2 Fri, 07/27/2007 - 08:46
I attempted to post my 'show config' results to you, but somehow they did not show up on the forum. Can you please confirm whether or not you got them?
