07-26-2007 10:19 AM - edited 03-05-2019 05:31 PM
Hi;
If any one have any idea that what is ios supported isis on 2500 series of router, i have 2520 routers with the image c2500-is-l.123-22.bin but unable to run isis, it gives error protocol not in this image.
Solved! Go to Solution.
07-26-2007 10:47 AM
Your image doesnot support it. You need atleast c2500-p7-l.122-23a.bin to support IS-IS on your router. Please see the attached out from feature navigator for the supported IOS.
Please use the feature navigator tool in future for IOS selection for your routers.
HTH,Please rate if it does.
-amit singh
07-26-2007 10:47 AM
-amit singh
07-26-2007 10:50 AM
You would need Service Provider or Enterprise Plus feature set to run IS-IS. Here's one image that you can use, c2500-p-l.12.2-17c.
Sundar
