unity connection 1.2 disable transfer prompt
Jul 26th, 2007
I am trying to meet a customer's request that I disable the "Please wait while I transfer your call prompt" in unity connection. In Unity versions prior to 4.2 I would remove the current prompt and replace it with a properly recorded blank one of the same name. I cannot find the correct prompt in connections to do the same task. Can anyone help out?
askq2forum Fri, 01/11/2008 - 04:02
Hi did you resolve this we have similar issue,thanks, Jaginder.
