WLC Software
Rob Huffman Thu, 07/26/2007 - 13:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi James,
Have a look at the Free TFTP Servers listed in this excellent post (no file size limit :);
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddf32e9
Hope this helps!
Rob
ankbhasi Thu, 07/26/2007 - 21:07
  • Cisco Employee,
Hi Friend,
WLC does not support XMODEM. Also I use Tftpd32 to upload images on my WLC and it works like a champ.
Good Luck!!
Ankur
*Pls rate all helpfull post
pmccubbin Thu, 07/26/2007 - 21:53
  • Silver, 250 points or more
I had the same issue and loaded the image via a WCS. You can get a 30 day evaluation license and install it easily on a dedicated server. What's more, if you decide to buy a license for the WCS all the configurations you made while using the 30 day license will be retained.
If you are doing any sort of implementation where you plan on having more than 2 controllers then the WCS is the way to go. It's the best method for keeping all your WLC configuration changes in sync and it can upload software images simultaneously to all of your WLCs.
Hope this helps.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
