IP SUBNET-ZERO
Answered Question
Jul 26th, 2007
I'm using the BUNDLE1841 with IOS ADVANCED SERVICES. I am having problems as ip subnet-zero command.
The router accept the command, but after to save the configurations, the show running, i don't see the ip subnet-zero on!
What it can be happening?
Peterson
Correct Answer by Richard Burts about 9 years 10 months ago
Peterson
Sunday is quite correct. In very old versions of IOS the default was no ip subnet-zero. The default changed a LONG time ago and in all versions of code which run on the 1841 the default is to enable subnet zero.
When Cisco changes a default in the code they are pretty good about showing the value in the show running-config for quite a while. And the command has been displayed in code for a long time. In very recent versions of code several of theses defaults are no longer showing up, including subnet-zero. But the behavior is still enabled. Sundar's advice about doing no ip subnet-zero is a good way to check it out.
Rick
Correct Answer by sundar.palaniappan about 9 years 10 months ago
Peterson,
IOS doesn't display most default configuration. 'ip subnet-zero' is a very likely a default configuration in the IOS version you are using. The one way to confirm that would be if you configure 'no ip subnet-zero' the command would show up in the running configuration.
Sundar
Overall Rating: 5 (2 ratings)
Correct Answer
sundar.palaniappan Thu, 07/26/2007 - 13:00
  • Green, 3000 points or more
Peterson,
Sundar
Correct Answer
Richard Burts Thu, 07/26/2007 - 17:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Peterson
Rick
Richard Burts Sat, 07/28/2007 - 18:29
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Peterson
Thanks for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read an answer that resolved the question. I encourage you to continue your participation in the forum.
Rick
