Router 1811 internet to workstations
Answered Question
Jul 26th, 2007
I have ISP connected between ADSL modem to router 1811 in FastEthernet0 port. Wowrstations connected in switchports 2-9 and they have not internet :(
Plz help i'm neewbe in cisco network and configuration. What wrong in config?
Router Config.
!This is the show startup-config output of the router: show startup-config
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname 1811
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret xxx
enable password xxx
no aaa new-model
resource policy
clock timezone PCTime 7
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
no ip source-route
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.0.1
ip dhcp pool sdm-pool1
import all
network 172.16.0.0 255.255.255.0
dns-server 172.16.0.1
default-router 172.16.0.1
ip tcp synwait-time 10
no ip bootp server
ip domain name renome-pb.ru
ip name-server 172.16.0.1
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-2201697271
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2201697271
revocation-check none
rsakeypair TP-self-signed-2201697271
crypto pki certificate chain TP-self-signed-2201697271
certificate self-signed 01 nvram:IOS-Self-Sig#3103.cer
username nowal privilege 15 secret xxx
interface FastEthernet0
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address xxx.yyy.134.158 255.255.255.252
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface FastEthernet1
no ip address
ip route-cache flow
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
shutdown
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address 172.16.0.1 255.255.0.0
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 xxx.yyy.134.158
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source static tcp 172.16.0.2 80 interface FastEthernet0 80
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 172.16.0.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
Correct Answer by spremkumar about 9 years 8 months ago
In your first post you haved mentioned about NAT overload and in the second post you are using nat pool.
Can you try removing the usage of pool and try with simple overload ?
May there are chances that your SP doesnt have a reverse route for the nat pool being used in your router..
regds
Overall Rating: 4.3 (3 ratings)
spremkumar Thu, 07/26/2007 - 19:56
  • Red, 2250 points or more
Can you try this and check ?
no ip route 0.0.0.0 0.0.0.0 xxx.yyy.134.158
ip route 0.0.0.0 0.0.0.0 FastEthenet0 xxx.yyy.134.157
regds
nowal1234 Thu, 07/26/2007 - 21:11
so,
ping from router to public ip successfully, but from work station ping don't go. And not access to Internet from workstation.
I'm edit my default confing
change in nat route configuration.
Now it look like this:
ip cef
ip dhcp excluded-address 172.16.1.1
import all
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
no ip bootp server
no ip domain lookup
description $FW_OUTSIDE$$ES_WAN$$ETH-WAN$
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
duplex auto
speed auto
interface Vlan1
ip address 172.16.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip route 0.0.0.0 0.0.0.0 FastEthernet0 xxx.yyy.134.157
ip http server
ip nat pool pool1 xxx.yyy.134.150 xxx.yyy.134.156 netmask 255.255.255.240
ip nat inside source list 1 pool pool1
access-list 1 permit 172.16.1.0 0.0.0.255
no cdp run
Correct Answer
spremkumar Thu, 07/26/2007 - 21:18
regds
nowal1234 Thu, 07/26/2007 - 21:41
back in first config not effect pings saves but ping from workstation to internet don't go
now nat and route conf is:
ip http server
ip nat inside source static tcp 172.16.1.2 80 interface FastEthernet0 80
access-list 1 remark SDM_ACL Category=16
no cdp run
spremkumar Thu, 07/26/2007 - 21:45
Can you try a ping from your local pc and paste the output of show ip nat translations here ?
Also can you do a tracert to external site and find the path its taking...
To verify the reverse route for your nat pool from the external world you can make use of any route-servers from where u can do a trace to ur nat pool and find out the path/results on whether its reaching ur router properly...
regds
nowal1234 Thu, 07/26/2007 - 22:32
Pro Inside global Inside local Outside local Outside global
tcp xxx.yyy.134.158:80 172.16.1.2:80 --- ---
Trace from my route1811 to external host
Tracing the route to 213.59.42.120
1 * * *
2 xx.yy.128.253 44 msec 44 msec 48 msec
3 xx.yy.128.254 48 msec 108 msec 44 msec
4 xx.yy.128.162 44 msec 48 msec 88 msec
5 xx.yy.128.106 80 msec 56 msec 56 msec
6 143.24.217.249 56 msec 48 msec 48 msec
7 185.161.70.53 48 msec 124 msec 452 msec
8 227.106.5.162 56 msec 48 msec 48 msec
9 213.59.42.120 48 msec 44 msec 44 msec
Trace from External host to xxx.yyy.134.158 (myhost)
1 <1 мс 1 ms 1 ms 10.2.0.1
2 3 ms 4 ms 4 ms gateway 34.231.42.22
3 4 ms 5 ms 5 ms host1 [227.106.5.138]
4 4 ms 5 ms 6 ms host2 [185.161.70.54]
5 307 ms 362 ms 363 ms host3 [143.24.217.250]
6 143 ms 142 ms 142 ms host4 [xx.yy.128.105]
7 185 ms 148 ms 149 ms host5 [yy.xx.128.165]
8 147 ms 151 ms 147 ms host6 [xx.yy.128.253]
9 * * * host7
10 192 ms 188 ms 188 ms www.myhost.ru [xxx.yyy.134.158]
Now ping going form workstation to public net but not by IP address, trying ping google.com not effect "server not found". In IE i can visit site by ip adress no by domain name. How can debug it?
spremkumar Thu, 07/26/2007 - 22:55
hi
under your dhcp config change the dns server ip address from 172.16.0.1 to the dns ip recieved from your SP.
You can get the dns details which can be used in ur lan from ur SP..
regds
nowal1234 Fri, 07/27/2007 - 01:04
All work. respect to you.
One more quiestion. ISP take me 8 public ip address under 1 adsl connect. How i can takes 2-3 ip to my didecate servers for public services. I have 3 cisco connected by scheme:
ISP-> Router 1811 -> ASA5505 -> Switch Catalyst 2960. On 2960 i plane take 3 VLAN every be have web-service this access from public net. All workstations connected to catalyst 2960 and sort by 3 Vlan
What service (route, nat, pat, trunk... etc) i should be up on cisco devices?
spremkumar Fri, 07/27/2007 - 01:12
i would suggest to have the public ips mapped onto your ASA so that your servers wont be exposed to the outside world.
For that you need to have the ethernet of the router configured in that public subnet and the outside interface of the ASA also to be part of the same subnet...
On the ASA you define the required access to the inside server ips with the one to one NAT configured.
regds
