setting up the VTI
Jul 26th, 2007
can I configure virtual tunnel between the two sites without using crypto isakmp enable?
I do have the interface tunnel setup on both ends with tunnel ip address and tunnel destination addresses with tunnel key.
spremkumar Thu, 07/26/2007 - 23:57
You can create GRE tunnels between your locations with encapsulation mode as GRE so that you can have the communication between locations done through the tunnel...
Instead of having IPSEC tunnels you can consider these tunnels but they are just an encapsulation mechanism and doesnt provide any kinda security to your data...
If you are concerned about security to the data transfer being done between the locations better look out for IPSEC tunnels
