Port Speed Trouble
Jul 26th, 2007
I'm having a bit of trouble here with the port speed on a few phones. It doesn't seem to matter which type of phone I use, 7911 or 7941. I have any area, All on the same VLAN, All points going to the same switch. When I connect a phone through the PC connection to the network, Every Network-based process becomes alot slower from that PC. I have set the Port speeds on the phone from Auto-Negotiate to 100 Full. The Switches Port speeds are also set at 100 Full. When I check the Network Statistics on the Phones Settings Menu, I can see that Port 1 is running at 100 Half and Port 2 is running at 100 Full? A few of the phones have both ports running at 100 Full and these phones don't have an issue with speed. Any advice would be appreciated.
