2960 and 3560 uplink failed after power failure
Answered Question
Jul 26th, 2007
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 04:33 by yenanh
Image text-base: 0x00003000, data-base: 0x00AA2F34
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
W0201-imislgca1 uptime is 1 day, 22 hours, 37 minutes
System image file is "flash:c2960-lanbase-mz.122-25.SEE2/c2960-lanbase-mz.122-25.SEE2.bin"
cisco WS-C2960-48TT-L (PowerPC405) processor (revision B0) with 61440K/4088K bytes of memory.
Processor board ID FOC1044X3DG
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Compiled Fri 28-Jul-06 07:19 by yenanh
Image text-base: 0x00003000, data-base: 0x00EB0F14
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
W0200-imislgbd2 uptime is 18 hours, 46 minutes
System image file is "flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID CAT1043NL0V
24 FastEthernet interfaces
We have this two equipments (show above) connected in this manner
3560 (fa0/4) <---> (Gi0/2) 2960
1) When we power up the 2960 with the UTP Cable connected, the uplink will not go up, we need to replug the cable then the link will come up.
2) The rebooting the 3560 even unpluggin the UTP does not resolve the problem.
Theres no log indicating why the interface was down
Please help... Thank you
Correct Answer by manmeetmarwah about 9 years 6 months ago
There might be a negotiation mismatch happening between the switches as one switch is having a fast ethernet port whereas the other switch is having a gigabit ethernet port.
You can try putting both the ports forcefully to 100 Mbps full duplex and then can verify their behaviour.
The commands for the above are:
3560 switch:
conf t
interface fa0/4
speed 100
duplex full
2960 switch:
conf t
interface Gi0/2
speed 100
duplex full
Manmeet
Pls rate.
Overall Rating: 5 (1 ratings)
Amit Singh Fri, 07/27/2007 - 01:50
Could you please paste the interface config for both the ports.
What happens when you reboot the 3560. Do you see the same behaviour on 2960 or 3560 side.
-amit singh
rgsantos Fri, 07/27/2007 - 23:22
3560
interface FastEthernet0/4
switchport mode trunk
2960
interface GigabitEthernet0/2
its on the 2960 side only, there are 2 3560, the interconnect are working fine on 3560 when powered up
Correct Answer
manmeetmarwah Fri, 07/27/2007 - 02:04
3560 switch:
conf t
interface fa0/4
speed 100
duplex full
2960 switch:
conf t
interface Gi0/2
speed 100
duplex full
Manmeet
Pls rate.
EPHRAIM MANI Sat, 07/28/2007 - 00:52
rqsantos, would like to know whether this is a new setup or this connectivity was working properly earlier.
Thanks EM
rgsantos Sun, 07/29/2007 - 16:37
Hi Tee,
Were not able to investigate this anymore. It worked when we force to 100/full
Thank you
