IP Phone agent
lpezj Fri, 07/27/2007 - 01:40
I think that, by now, it is no possible. The agent manually has to go to the Ready state.
Hope this helps,
Juan Luis
Justin Brenton Tue, 08/07/2007 - 15:14
In IPCC Admin Page, goto Subsystem->RMCM->Resources->select a resource and you will see automatic available. Enable this and your agent should be automatically ready.
Hope this helps, it's the only thing I could find that may work.
