Jul 27th, 2007
I have a 3640 router, when I want change the name of my router I have the following message :
% Hostname "CPE-TEST--LLA-01" is not a legal LAT node name, Using "CISCO_90A8C0" , could you explain me what is it means? thanks in advance;
purohit_810 Fri, 07/27/2007 - 05:04
Are youconfiguring same host name that is already used?
Dharmesh Purohit
Pavel Bykov Fri, 07/27/2007 - 05:41
I found this:
% Hostname contains one or more illegal characters.
% Hostname is not a legal LAT node name, Using "CISCO_XX"
Try doing "hostname router", then performing desired command. Workaround says to restore hostname to original value.
yavuz.ozdemir Fri, 07/27/2007 - 06:00
No, this is a new config. without other hostname.
The original value is router!
Edison Ortiz Fri, 07/27/2007 - 06:37
Local Area Transport (LAT) protocol is the protocol used most often to connect terminals to DEC hosts.
The LAT protocol is similar to TCP/IP's Telnet protocol in that it allows a user at one site to establish a connection to a host at another site, then passes the keystrokes from one system to the other. A user can establish a LAT connection through the terminal server to a DEC host, simply by entering the host name.
It sounds like the IOS you are running, has terminal services features.
To read more about LAT, see:
EPHRAIM MANI Sat, 07/28/2007 - 01:41
I suppose what slidersv meant was provide the hostname as "routernew" then again change it to the deisred one. If you still face the same problem try using underscore "_" instead of hyphen "-".
Kindly rate all the posts if its helpful
