show object-group in 7.x
Jul 27th, 2007
We had the show object-group command in 6.x wherein we will able to get the hitcnts on the object groups. But in 7.x this is not available. The show access-list gives the hitcnt for object group but i am looking for some command which gives a similar ouput like this
as in 6.x
object-group network abc-destination (hitcnt=1081)
network-object x.x.x.0 y.y.y.0(hitcnt=340)
network-object x.x.x.0 y.y.y.0 (hitcnt=94)
Is there any show command available in 7.x which give this output.
Devanathan.B
purohit_810 Fri, 07/27/2007 - 05:57
Check by this command:
sh running-config object-group network {ID}
Dharmesh
sansari Thu, 09/18/2008 - 11:22
The configuration guide for 7.2(1) states that we should be able to do show object-group, but the parser does not even recognize the "object-group" token. Any idea why?
