Paolo Bevilacqua Fri, 07/27/2007 - 03:59
What exact kind of HWIC are talking about ?
In any case, there are never power isssues with WIC/VIC/HWIC, that is, the default power supply for the specific router type can power any type in any combination, and the maximum PS power drain is what you have to consider in your calculations.
Hope this helps, please rate post if it does
