07-27-2007 04:28 AM - edited 03-18-2019 07:37 PM
Hi All,
I have sentup a hunt group for an external number but when I call it ,it goes throught the list but gets a busy at the 5 entry no matter what extension it is even voice mail?
Solved! Go to Solution.
07-27-2007 06:06 AM
Hi Stephen,
Sorry about that, I was thinking AA Hunt Groups. Here is what I would look at in your scenario;
max-redirect number
Example:
Router(config-telephony)# max-redirect x
Sets the number of times that a call can be redirected within a Cisco Unified CME system.
number - Range is 5 to 20. Default is 5.
Note: This command is required if the number of hops is greater than 5. (which yours is :)
Hope this helps!
Rob
07-27-2007 05:21 AM
Hi Stephen,
I am guessing that you are working with CME, if so, I would have a look at these three config parameters;
**param queue-len x
param max-time-vm-retry x
param voice-mail xxxx
From this good doc;
Hope this helps!
Rob
07-27-2007 05:53 AM
Hi Heres my Huntgorup config, not sure where or what I need from that config?
ephone-hunt 1 sequential
pilot 01603502198
list 5433, 5412, 5423, 5414, 5430, 5409
final 5198
preference 0 secondary 10
timeout 3, 3, 3, 3, 3, 3
07-27-2007 06:06 AM
Hi Stephen,
max-redirect number
Example:
Hope this helps!
Rob
07-27-2007 06:18 AM
Spot on , thanks
07-27-2007 06:30 AM
Hi Stephen,
You are most welcome :)
Take care,
Rob
