CCNA lab study
Jul 27th, 2007
Hello all,
1st timer here. Just wondering if having 3 2950's is a good switching environment to have to study for the CCNA? I also have 3 3600's with T1-wic (for each) as well. Is this a good enough lab?
JorgeV.
vazquez.jorge Fri, 07/27/2007 - 07:52
Nevermind, I just found out that having 2950's are perfect to have for ccna. I was just worried about ISL not supported on these platforms.
Can anyone confirm my 3600 set-up?
JorgeV.
mohammedmahmoud Fri, 07/27/2007 - 08:20
hi,
Its a great lab setup for CCNA, yes the 2950 doesn't support ISL but its not a big deal, as for your routers the 3600 are more than great, but what exact type of T1 interfaces are your WIC.
HTH,
Mohammed Mahmoud.
vazquez.jorge Fri, 07/27/2007 - 11:00
Hello Mohammed,
Thanks for the reply. I currently have wic-1dsu-t1 cards. I should be able to use these cards for all routing protocols out there. Am I correct on this?
JorgeV.
