SSL VPN on VPN concentrator
Jul 27th, 2007
Currently I am using IPSec client VPN. I would like to know what steps I should do to enable/configure SSL VPN (clientless VPN)on my VPN Concentrator 3030? I am using PIX as firewall and Microsoft Active Directory with a Radius server for user auth.
Can anyone pleaaaaseee guide me?
Thanks in advance.
Overall Rating: 4 (2 ratings)
jessica_j Fri, 07/27/2007 - 21:56
Thanks for this link and its useful. Also I would like to know -
(a)Since an SSL certificate need to be generated, can I generate this using the concentrator itself, because iam not having any other certification generation mechanism available now.
(b) Can I use Microsoft Active Directory for the Radius Authentication? Any documentation links available ?
(c) If I enable SSL VPN solution, can I have two groups of users, like one group which can use IPSec client and other group can use SSL VPN via a web browser?
Many Thanks..
Jessica
Jagdeep Gambhir Mon, 07/30/2007 - 04:57
  • Red, 2250 points or more
Hi Jessica,
1). Yes you can generate cert on VPN concentrator. Check step 11 in the link,
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a008055641a.shtml#configuration
2). Yes, you can use MS IAS for Radius authentication,
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00800949b4.shtml
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a0080094700.shtml
3). Yes, you need to select the protocol(like SSL or ipsec) in the group set up.
Please rate if that helps !
~JG
