Building Callmanager cluster
Jul 27th, 2007
I understand that when deploying a CCM cluster the Publisher must built first.
Does it also have to be attached to the network before commencing with Subsciber build?. Cannnot seem to find the document at the momment expaining the prerequisites and procedures?
tia
rob.huffman Fri, 07/27/2007 - 07:05
Hi Ajaz,
Yes, this is the recommended method so the Pub/Sub relationship db replication can take place properly.
Hope this helps!
Rob
mohamedtag Fri, 07/27/2007 - 08:17
Hello Anawaz ,
Yes , Everytime you Install one of the Subscribers , The Subscriber should be able to contact the PUBLISHER.
M.Tag
