2611 Boot issues
rdaggett1
I would like to 1st say thank you all for looking and providing support to a newbie.
I did the recovery option via xmodem .... when I reset it I get the following:
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 32768 Kbytes of main memory
open: file "n" not found
open(): Open Error = -1
loadprog: error - on file open
boot: cannot load "flash:n"
if I do a break to get to rommon and type boot and the rommon command line .... the router boots fine .... I dont know what is going on ....
thanks again for looking and repling if possible.
10 Replies 10
ankbhasi
Hi Friend,
Once the router boots fine manually from rommon can you paste the output of "sh version" , "sh boot" ?
Ankur
here it is and thank you.
IOS (tm) C2600 Software (C2600-IO3-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 21-Jul-05 19:55 by dchih
Image text-base: 0x80008098, data-base: 0x80D545B8
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IO3-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
Router uptime is 3 minutes
System returned to ROM by reload
System image file is "flash:c2600-103-mz.123-15a.bin"
cisco 2611 (MPC860) processor (revision 0x202) with 28672K/4096K bytes of memory
Processor board ID JAB031408JN (2668064774)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
Bridging software.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x3922
Hi Friend,
So I believe the problem is with the config register value. Check the last line of "sh version" it is set to "Configuration register is 0x3922" so change it to 0x2102 and I believe you will be good to go.
Router(config)#config-register 0x2102
Router(config)#wr mem
Router(config)#reload
Ankur
*Pls rate all helpfull post
no luck same error
here is what I get when I do a sh config
Using 722 out of 29688 bytes
version 12.3
hostname Router
boot-start-marker
boot system flash c2600-io3-mz.123-15a.bin
boot system tftp c2600-103-mz.123-15a.bin 255.255.255.255
boot-end-marker
no logging console
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
interface Ethernet0/0
ip address 169.254.x.x.255.255.248
half-duplex
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
no ip address
shutdown
half-duplex
interface Serial0/1
no ip address
shutdown
no ip http server
ip classless
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
Hi Friend,
Give this a try
Router(config)#no boot system tftp c2600-103-mz.123-15a.bin 255.255.255.255
Router(config)#no boot system flash c2600-io3-mz.123-15a.bin
Router(config)#boot system flash:c2600-io3-mz.123-15a.bin
Router#wr mem
Router#reload
If this also does not work, give a try to open a router and reseat the flash and if still no luck get you flash replaced.
Ankur
that had no impact either I will reseat the flash when I get home ... I am remoteded into my laptop from work right now ...
Thank you again
Wondering ... if it were bad flash wouldnt it have issues loading the IOS .... ever use ebay to buy flash for a router as it is dirt cheap there
just got it to say the following on the sh ver at the end
configuration register is 0x2102
is the progress ??... but I still need to go into rommon and type boot
OK I reseated the flash no luck. The IOS right now is in flash .... is this where it sould be or in NVRAM or DRAM? I am sorry I am a newbie ..... if it should be in another RAM type how do I clear it and then copy it from flash?
thank you all
The IOS must reside in the flash, and when the router boots up it loads it into the RAM, ok i'll say for a last try, why don't you format the flash, and copy the IOS once again and then we can see, if the problem persists then most probably it is a flash hw problem.
HTH,
Mohammed Mahmoud.
ok...
could you outline the process of formating everything .... flash and ram
thank you
