QoS: Match VLAN feature
limtohsoon
Hi Sir,
I'm configuring a Catalyst 3550 to meet the following requirement:
*** VLAN 12 should allow no more than 2Mb total throughput ***
I came across the following solution:
mls qos
mls qos aggregate-policer 2MB 2000000 375000 exceed-action drop
class-map match-all VL12
match vlan 12
match class-map class-default
policy-map MyPolice
class VL12
police aggregate 2MB
interface FastEthernet0/1
switchport mode access
switchport access vlan 12
service-policy input MyPolice
interface FastEthernet0/2
Questions:
(1) Is the command "match class-map class-default" necessary? I think the command "match vlan 12" alone suffices.
(2) I understand that the Match VLAN feature allows us to classify network traffic on the basis of the Layer 2 VLAN identification number. Does it take effect when applied to access links, like the example above? Or should it be applied to trunk links carrying that VLAN to be matched?
I'd configure it simply as follows:
policy-map MyPolice
class class-default
Please advise.
Thank you.
B.Rgds,
Lim TS
Not applicable
class-map class-map-name command Creates a class map using the name you enter for the traffic class and enters class-map configuration mode. But match vlan {vlan-id | vlan-id1-vlan-id2} command defines one or more VLANs to use as match criteria against incoming packets to classify traffic.
mmoranzo
Lim,
I have the same doubt. Could you found the answer?
I have the same requirement as you (VLAN XX should allow no more than 10Mb total throughput).
Thanks and regards. Martín.
