enabling multicast routing 3750
Jul 27th, 2007
hi all
i am trying to enable multicasat routing on a 3750 switch
one port is configured as a routing interface with ip address
according to cisco site it should just be a case of entering 'ip multicast-routing distributed' followed by ip pim config.
unfortunately the 'ip multicast-routing' command is not available.
my switch is running ipbase-mz.122-25.SEE2
can anyone please help?
thanks in advance
Overall Rating: 4.5 (2 ratings)
jwdoherty Fri, 07/27/2007 - 08:21
Believe you might need the IP Service image to obtain multicast routing support.
Edison Ortiz Fri, 07/27/2007 - 08:23
You need this image for multicast routing, c3750-ipservicesk9-mz.122-25.SEE2
