paolo bevilacqua Fri, 07/27/2007 - 08:34
  • Hall of Fame,
    Founding Member
All the ISR router are nice. Really a budget decision because all the models are quite capable.
spremkumar Sun, 07/29/2007 - 19:39
  • Red, 2250 points or more
It depends on how much bandwidth you are going to have in the router and also the kinda ports/interfaces you require in them.
You may also need to check the features like VPN(IPSEC)/remote access vpn and other feature requirement in your network so that you can choose the best bet for your customer environment..
regds
