NAC - Issues with Switch, CAM and SNMP
Jul 27th, 2007
I am installing a CAS and a CAM for the first time. My first step is to change vlans in 2950 switch, using the CAM.
My topology is out-of-band real ip gateway.
I have the switch in CAM, I configured port profile (auth vlan (10), default access vlan (11) and access vlan (11)). I also assign this new port profile in one port of the switch.
By default I put the access vlan (11) in all switch ports.
My problem is when I connect a PC to the port controled by the CAM. CAM should change the port from vlan 11 to vlan 10 and I cannot acheive that.
This way I can not test PBR, and the CAS.
I also tried to put the controled port on auth vlan (10) and the auth page is not displayed in the browser.
Can you give me a help?
Best regards,
Jo?o Carvalho
