Is ipbasek9 a feature upgrade to ipbase?
Jul 27th, 2007
Looking for an upgrade for our 3750s currently running c3750-ipbase-mz.122-25.SEE1. I keep running into ipbasek9. What's the difference between ipbase and ipbasek9? Is there a cost associated with going to K9?
Overall Rating: 5 (1 ratings)
Edison Ortiz Fri, 07/27/2007 - 09:13
  • Hall of Fame,
    Founding Member
ipbasek9 will give you SSH, SCP and Kerberos support. You can download the image if you have a CCO account with a contract. Legally, you need to inform a Cisco reseller and purchase the upgrade license.
jamesross Fri, 07/27/2007 - 09:36
I have a CCO account. Going through the Software Advisor for an updated IPBASE IOS for SEE1 and it keeps giving me an IPBASEK9 version. Wondering if K9 is the default...
Edison Ortiz Fri, 07/27/2007 - 09:50
  • Hall of Fame,
    Founding Member
Interesting, I don't use Software Advisor for download, just for investigating features on a IOS set.
The latest IPBase for 3750 is c3750-ipbase-mz.122-37.SE1.bin
and I found it by going to
http://www.cisco.com/kobayashi/sw-center/
Switches Software
LAN Switches
IOS Software
jamesross Fri, 07/27/2007 - 10:04
I went to the link and chose CAT3750/IPBASE and got c3750-ipbasek9-mz.122-37.SE1.bin. I don't get it.
jamesross Fri, 07/27/2007 - 10:49
The only feature upgrade I can find for the 3750-SMI is advanced IP services and Enhanced Multilayer Upgrade kit. If K9 is the sugguested upgrade then I want to make sure it's legit before I download it.
Edison Ortiz Fri, 07/27/2007 - 10:56
  • Hall of Fame,
    Founding Member
I don't understand how are you getting to that screen. Very different than mine. Perhaps it has to do with our CCOs (different rights) ?
If you see my screen, you should be able to download 3750 IPBase w/o Crypto.
