Calls IP Phone>h323gateway>PSTN use codec g729 instead of codec g711
Hello everybody.
I have a CallManager 4.2(3) with h323 gateway. When I call from IP Phone through h323 gateway to PSTN, the codec is g729 I dont have configure any region only the default which use g711.
But when I call backwards from PSTN>h323gateway>IP phone the codec is g711 which is correct.
The IP Phones are on the LAN so I dont need to use the codec g729.
How can I force the calls from IP PHONE>H323GATEWAY>PSTN to use codec g711??
Walter Flores
gogasca Fri, 07/27/2007 - 18:02
Hola Walter,
Check the dial-peer voip in IOS GW and configure either a voice class codec or hardcode the codec. (ie codec g711ulaw)
Since regions are already configured.
Hola gogasca thank for answering.
I already configure de codec g711aLaw on dial-peer voice XXX voip with target to the CallManager, because when I receive a call from PSTN>h323gateway>IP phone codec is g711alaw.
The problem is when I call from IP Phone>h323gateway>PSTN the codec is g729.
I dont know why, because I dont have any region configure on the CallManager.
And I have this problem with all IP Phones installed on the LAN.
Regards Walter
gogasca Fri, 07/27/2007 - 22:52
Check which is your incoming dial-peer...
Do a show call active voice find out...
maramosm1 Wed, 09/07/2011 - 18:05
Try this, I hope it help you.
dial-peer voice 3801 voip
description PSTN A IP PHONES
destination-pattern 39..
session target ipv4:
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
Senthilkumar Sankar Wed, 09/07/2011 - 19:02
Hi Walter,
You have stated "I have added a new dial-peer in order to receive calls from PSTN to Cisco Unity" an you have adjusted that.
Then when you make a call from IPPhone to PSTN, it uses this dial-peer, I would suggest you to have different dial-peers for specific patterns in your setup.
