Event viewer errors \IWAM_Guest logon failure
Jul 27th, 2007
Our event viewer is getting flooded with the following errors. DCOM got error"Logon failure: user account restriction. "and was unable to logon \WAM_Guest in order to fun the server.
The other error which follows is
The server failed to load application 'LM/W3SVC/1Root/CCMCIP the error ws "The server process could not be started becasue the configuration identity is incorrect. Check the username and password.
Any ideas????
gogasca Fri, 07/27/2007 - 17:55
  • Green, 3000 points or more
Could you please, paste both errors as they appear in EV and try to run adminutility.exe afterhours.
