Pots dial peer issue with T command
littledavewhite
having touble with dial peers when the T command is used. I have a pots dial peer as follows.
dial-peer voice 999 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
I use the show dialplan number 91234 command and no dial peer is matched. No other dial peer exist all have been removed. If i use the ^9. instead of 9T all works but all digits are forwarded down the E1. I have also ried a dial peer with 5T and get the same results. I have used the 9T for outside pstn access before with no issues, the 9 is removed and all other digits forwarded.
software on router is
c2800nm-ipvoicek9-mz.124-15.T1.bin
paolo bevilacqua
test the number with "show dialplan timeout". It should definitely work as per documentation.
paolo bevilacqua
doucamp
I do believe when using a T pattern with "dialplan number" command you have to place a # at the end to signify the end of inter digit timeout.
By default either will work, but since you can change the significance of # from terminator to regular DTMF symbol, "timeout" is the safest form.
Thanks for all the advice, the timeout command worked after the show dialplan number command.
Thanks for the help guys, another one for the little black book.
